TIME TO REBUILD (currently 8,241 views) |
Simon_Pike |
Posted on: April 25th, 2019, 14:38:57
MANAGED TO GET MY HANDS ON THIS,VERY VERY LUCKY MKIV |
 | Last modified May 20th, 2019, 11:45:13 by Simon_Pike |
Simon_Pike |
Posted on: April 25th, 2019, 14:39:48
EVERYTHING IS NEW ON IT,THE GUY HAD BEEN RSTORING IT FOR 35 YEARS |
Reply: 1 - 51 |
Simon_Pike |
Posted on: April 25th, 2019, 14:40:35
JUST NEEDS FINISHING |
Reply: 2 - 51 |
Posted on: April 25th, 2019, 16:52:01 |
Nice a quick tidy then on the road. Mike |
Reply: 3 - 51 |
Philip_Davenport |
Posted on: April 26th, 2019, 10:40:03 |
Looks great !
If V registration is 1979, then this car is now historic tax and needs no MOT... so you can drive it on the road as you like .. Happy Days! |
Owner since March 2019 of SWD 588G Chassis: 7213 | Last modified April 26th, 2019, 10:48:31 by Philip_Davenport |
Reply: 4 - 51 |
Simon_Pike |
Posted on: April 26th, 2019, 17:20:10 |
unfortunatly according to the gov website it does need mot and tax as it was built after jan 1979. But that doesnt matter as it still has the v5 from 1979 and if you apply for a new one they will come and inspect the vechicle to see if its a ringer,but if you get it mot,d first they look at that as being inspected so will supply a new v5 https://www.gov.uk/historic-vehicles |
Last modified April 26th, 2019, 17:20:56 by Simon_Pike |
Reply: 5 - 51 |
Simon_Pike |
Posted on: May 14th, 2019, 10:41:05
Picked up a brake conversion kit from himleyhall mini show. No major problems fitting it,but i did have to grind a bit of the hub carrier to get the bolts to line up |
Reply: 6 - 51 |
Simon_Pike |
back on 10,s how it should be |
Reply: 7 - 51 |
Philip_Davenport |
Posted on: May 16th, 2019, 10:03:08 |
that looks the business ...nice !
tell the kids that they can't play basketball in the garden |
Owner since March 2019 of SWD 588G Chassis: 7213 | Last modified May 16th, 2019, 10:04:08 by Philip_Davenport |
Reply: 8 - 51 |
Posted on: May 17th, 2019, 19:11:19 |
It looks very nice. Mine's a V-reg first registered in 1980 so I'll have to MoT and tax it.
What's that sticking out of the bonnet? It should only need a small bump for a single SU. The original bonnet was designed for twin carbs.
If you want to make a new front panel, the inside of a Mini windscreen makes a good mould. |
Last modified May 17th, 2019, 19:17:54 by admin |
Reply: 9 - 51 |
Simon_Pike |
Posted on: May 17th, 2019, 21:41:48 |
Quoted from admin, posted May 17th, 2019, 19:11:19 at here |
Thats the washer bottle it was just resting on the rocker cover,I dont know why the previous owner cut such a big hole in it.new bonnet required I think |
Last modified May 18th, 2019, 07:29:20 by Simon_Pike |
Reply: 10 - 51 |
Simon_Pike |
Sold those ridiculous 7x13" and at last got my wheels done, 10" mistrals |
 | Last modified May 21st, 2019, 10:04:01 by Simon_Pike |
Reply: 11 - 51 |
Simon_Pike |
just needs some arches now |
Reply: 12 - 51 |
Simon_Pike |
next job,the saggy headliner. there was two options on this 1 tear back the headliner from the windscreen,door,rear window pillars 2 cut the headliner straight down the middle due to the fact it was fitted so well around the pillars and shaped and stuck down really well i didnt wont to do this as and taking the headliner totaly of ones side and getting it stuck back up on my own i would never have got it right. so option two it was,this allowed me to get access to the rear hinge area aswell. luckily the seam were i cut in the middle went back really well |
Reply: 13 - 51 |
Simon_Pike |
was very worried at this point |
Reply: 14 - 51 |
