  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  7213
0 Members Browsing (47 Guests)
Pages: « 1, 2, 3, 4, 5, 6 » : All Reply Recommend Print
  Author    7213  (currently 11,024 views)
Philip_Davenport
Posted on: May 6th, 2019, 16:43:15
Got some dials for Mikes dash...
Owner since March 2019 of SWD 588G Chassis: 7213
Private Message Reply: 60 - 83
Philip_Davenport
Posted on: May 6th, 2019, 16:44:07
A bit rough on the back ..but might polish up...
Private Message Reply: 61 - 83
Philip_Davenport
Posted on: May 6th, 2019, 16:48:01
So anyway, spent the day putting the rear subframe back together.. took ages!!!
Private Message Reply: 62 - 83
Philip_Davenport
Posted on: May 6th, 2019, 16:49:45
Hi tech....
Private Message Reply: 63 - 83
Philip_Davenport
Posted on: May 6th, 2019, 16:52:45
Not sure if this is right...maybe too much rubber??
Private Message Reply: 64 - 83
Simon_Pike
Posted on: May 7th, 2019, 08:44:20 Quote Report to Moderator
lump hammer,love it phillip
Private Message Reply: 65 - 83
Philip_Davenport
Posted on: May 7th, 2019, 15:17:50 Quote Report to Moderator
Hi Simon, it was good to meet you on Sunday. Lump hammer is a change from angle grinder ... none of the bolts/nuts come off... grr!
Private Message Reply: 66 - 83
Philip_Davenport
Posted on: May 8th, 2019, 08:07:14
Had to empty out the boxes in the attic, the boxes in the shed and ....lots of other boxes to find these.. (they were no good from the old sub-frame, and they were all the smaller dia ones anyway)
So happy today
Private Message Reply: 67 - 83
Philip_Davenport
Posted on: May 9th, 2019, 08:06:55
Bought some 50mm snap hook clips for the seatbelts from ebay..
Private Message Reply: 68 - 83
Philip_Davenport
Posted on: May 9th, 2019, 08:09:42
The old ones had been eaten by a mouse..
Or maybe a big scary monster
Private Message Reply: 69 - 83
Philip_Davenport
Posted on: May 9th, 2019, 08:10:50
Look okay but need two more clips..
Private Message Reply: 70 - 83
Simon_Pike
Posted on: May 9th, 2019, 08:23:15 Quote Report to Moderator
Quoted from Philip_Davenport, posted May 7th, 2019, 15:17:50 at here
and you too phillip,good luck with the build its coming on nicely and i will see you and your marcos soon
Private Message Reply: 71 - 83
Philip_Davenport
Posted on: May 13th, 2019, 13:08:58 Quote Report to Moderator
No pictures .. but was working .. wanted to finish rear sub frame, petrol tank, rear windscreen and the stuff at the back...
-Not sure whether to open up rear brake pressure regulator valve to see if it looks okay... or leave it until I see that it is broken and the rear wheels lock up under hard braking.. I'm replacing all the brake pipes so it will be easy to maintain the valve later.
-Not sure if I should get B&Q silicone bathroom sealant and seal the tank... maybe just before the carpets go down. I will seal from underneath.
-Thinking about how to route rear to front fuel pipe and brake pipe, to stay away from exhaust. Probably go high, to avoid scraping it on road..
-Couldn't finish fitting fuel tank: fuel pipe that exits tank had an (old-style) square-ended brass male fitting, seating on a tapered female seating on tank. It didn't tighten up... so got to buy a new petrol pipe with newer fitting.
-Couldn't finish fitting rear hand brakes on sub frame as missing one split pin ..£0.05 from Mini Spares.
-Finally last two snap hook clips arrived for seat belt, then I was told we should get new harnesses.. eek ! At least new harnesses won't have wrong sized (75 mm) clips.
Private Message Reply: 72 - 83
Philip_Davenport
Posted on: June 5th, 2019, 14:06:34
yippee.... The registration doc arrived today... No checks or hassle... just lots of waiting … I was worried ..
So back to the monster on the driveway
Private Message Reply: 73 - 83
Posted on: June 5th, 2019, 17:02:08 Quote Report to Moderator
Congrats
Private Message Reply: 74 - 83
Powered by e-blah Platinum 7 Final © 2001-2004   -   July 3rd, 2022, 23:39:27
Files opened: 112 | Files closed: 112
