Headlight Cover Fixings (currently 6,888 views) |
Tim Frankland |
Posted on: August 25th, 2015, 18:52:56 |
I was wondering if anyone had any ideas for how to fix new headlight covers? The club haven't sold the fixings for a while so something else must be used. Are there any existing fixings available or do people make their own?
Any help with this would be greatly appreciated. |
Posted on: August 25th, 2015, 19:10:37 |
Something I always keep thinking I should fit, but as Tim says with no fixing kits I'm not sure how to attach them! |
Reply: 1 - 24 |
Herve_barriere |
Posted on: August 25th, 2015, 20:23:02 |
Hi
Mine are fixed with 3 stell plate at right angle. One side in fiber, the other in the headlight cover. I have add seal not for watertightness but for deformation when you scew.
Reply: 2 - 24 |
Posted on: August 25th, 2015, 22:23:37 |
I've just put headlamp covers on the Jem for the first time after owning the car for 20 years (but I did have to rebuild one headlamp recess that had been repaired to the wrong shape.
I decided not to use steel brackets but to fit a couple of tabs on the shell at either side near the top and use countersunk self-tapping screws. At the front end there's a longer screw into a raised area of the shell. I'll get some photos tomorrow.
Our original fixing kits comprised two stainless steel tongues at the back of the cover that located in slots cut into the shell above the headlamp unt, and a bracket near the front on the outside. |
Reply: 3 - 24 |
Posted on: August 26th, 2015, 14:14:37 |
I've just found some fixings on eBay that look about right, now just need to order some headlamp covers!
Who in the club has a stock of these? Will probably be easiest to collect at Castle Combe, if possible. |
Reply: 4 - 24 |
Tim Frankland |
Posted on: August 26th, 2015, 20:43:54 |
Thank you all for the advice and pictures.
There seems to be a few small brackets available on ebay and in hardware stores. I bought some today so will see how that goes but the tab approach also sounds good and more discreet, I would be interested to see pictures of them.
Andy Wright deals with spares and has the covers, I bought mine via Roger Garland. |
Reply: 5 - 24 |
Rodger Howard |
Posted on: August 26th, 2015, 23:10:34 Attachment: mmgt67.jpg - 32.64 KB (5794 views) |
you could try this |
Reply: 6 - 24 |
Steve_Schmidt |
Posted on: August 26th, 2015, 23:24:30 |
Unashamedly copied from Geoff Dunlop's car. A stainless-steel tongue held on by a pair of countersunk bolts through the acrylic sits above the headlight and slots into the bodywork. There's a single mushroom-headed stainless-steel bolt right at the front that screws into a captive nut epoxied into the nose.
Steve (MM 7056) Downunder http://www.mm7056.wordpress.com |
Logged |
Reply: 7 - 24 |
Posted on: August 27th, 2015, 18:41:49 Attachment: cover.jpeg - 120.23 KB (5801 views) |
This is the Jem arrangement. |
Reply: 8 - 24 |
Posted on: August 27th, 2015, 18:44:06 Attachment: tab.jpeg - 64.33 KB (5797 views) |
This is the outer tab |
Reply: 9 - 24 |
Tim Frankland |
The photos below show what I went for. It happened to be that some brackets I bought from Homebase (20mm) fitted perfectly with the holes in the headlight cover. I then superglued the nut to the inside of the bracket.
Thanks for all the advice and photos, there seem to be infinite ways to do the job! |
Reply: 10 - 24 |
Tim Frankland |
Close up |
Reply: 11 - 24 |
Gary Marlow |
Posted on: August 29th, 2015, 12:11:49 |
High jacking the link a bit, anyone got any mk1 headlight covers they want to sell, don't have to be perfect as long as they are in one piece. Cheers. Gary |
Reply: 12 - 24 |
Posted on: August 29th, 2015, 13:58:44 |
The club never had any Mk.I headlamp covers althogh the factory obviously had them for the Le Mans car. I gess if anyone has any they will have been specially made. |
Reply: 13 - 24 |
Posted on: August 30th, 2015, 17:22:57 |
How different are they could you cut the club ones down (easliy cut with a jigsaw with an aluminum blade) or reshape them in an oven. Mike |
Reply: 14 - 24 |
