A few questions (currently 4,514 views) |
Alex_Rowbottom |
Posted on: May 23rd, 2014, 14:13:30 |
Hi guys I have a couple of questions and was wondering if any of you would be able to help
Firstly I know that a number of people have moulds for the mini marcos' and maybe even other kit cars so I was wondering what moulds are available for use if needed?
Secondly Has anyone done an engine conversion on a mini marcos? For example honda vtec, vauxhall red tops, Yamaha r1, or any others?
Finally are there any damaged shells around that might be available?
Regards
Alex |
Posted on: May 23rd, 2014, 16:04:35 |
I have moulds for: Doors Bonnet Front panel Tail gate Rear body from doors back (no floorpan) My brother has a removable front end mould
I started to fit a Suzuki swift gti engine/gearbox to a mk5 she'll but my brother now has it and it never made it to the road...... yet.
Crashed ones do come up but not often. I have one that I bought from Scotland. Mike |
Reply: 1 - 113 |
Alex_Rowbottom |
Posted on: May 23rd, 2014, 18:32:51 |
Which mk marcos are they of? Is that your profile picture?
Alex |
Reply: 2 - 113 |
Posted on: May 23rd, 2014, 19:36:05 |
AJEC Racing tried to do a Zcars rear engine conversion with a Honda R engine. See http://www.minimarcos.org/memcars/honda/ It wasn't very successful and is being converted back to standard in USA.
Mike Shilvock built a racer with a 2-litre Vauxhall engine in the back. There wasn't much left of the original car! |
Last modified May 23rd, 2014, 19:37:21 by admin |
Reply: 3 - 113 |
Posted on: May 23rd, 2014, 21:18:26 |
Bonnet fits all Front panel fits most (not the few cars that have one piece bonnets ie some mk4/5) Doors fit mk3 on but I suspect they may fit earlier they may need a fettle depending on door catch used. Rear hatch late mk3 on Front end will fit all but was taken from a mk3 racer Rear body mk1 to mk3 but could be made to fit others. Plus I have some random odd bits
Yes that is mine in my profile and the mk5 swift powered was also a crashed car plus I've rebuilt 4 other crashed cars for club members. Mike |
Reply: 4 - 113 |
Alex_Rowbottom |
Posted on: May 24th, 2014, 11:49:12 |
Do you have any pictures of the moulds and the pieces which it makes? |
Reply: 5 - 113 |
Posted on: May 24th, 2014, 16:16:47 |
A shame there haven't been more attempts at re-engine'ing the MM. I really do think if there was a more modern alternative engineered for this kit, more new builds might be undertaken. When (if!) my car is every on the road, I've got a couple of spare subframes I'd like to play around with. The availability of Nissan Micra units could be a good starting point I think. Good look in finding a project Alex, and in sorting an alternative power unit. Mike - I don't suppose you're going to start a production run of carbon fibre panels are you? |
Reply: 6 - 113 |
Alex_Rowbottom |
Posted on: May 24th, 2014, 16:27:36 |
I wanted to try and do a 400bhp honda vtec awd Iv been looking into subframes and kits. I was going to look Into trying to make a road legal track marcos with carbon fibre panels which is sorta why I wanted to know who had moulds and so on. Regards Alex |
Reply: 7 - 113 |
Posted on: May 24th, 2014, 20:34:19 |
Alex, There is a kit, as I'm sure you know, from America that uses the 4wd set up from the CRV which fits into a mini. Not sure the bonnet height will allow such an easy conversion, and a space frame set up would probably be better, but you did say you were looking for a track car! And I'm sure there are pictures of a carbon fibre MM from Japan on the forum somewhere. But keep us all updated on your plans. |
Reply: 8 - 113 |
Alex_Rowbottom |
Posted on: May 24th, 2014, 21:02:11 |
Yeah it's by minitec I have looked into it but I work in a car body shop on the weekends and have learnt bits and pieces of fabrication so I may give it a go at making one but we will have to wait and see but I'm going to see if I can get hold of some moulds some how and try and do the carbon fibre work Aswell
Alex |
Reply: 9 - 113 |
Alex_Rowbottom |
Posted on: May 25th, 2014, 18:38:10 |
Well today I have been looking into carbon fibering. I have been looking at what is needed to do it and what steps to do it in and so on so I now need to find the moulds to have an attempt at doing it. The one thing which I couldn't find out was sticking the panels together once they are made can anyone spread some light on this? Also does anyone have any moulds in the West Midlands?
Alex |
Reply: 10 - 113 |
Posted on: May 25th, 2014, 21:59:07 |
If you have never used carbon fibre before find a college that does a course as your life could depend on your laminating skills. Having used grp/frp for 20 odd years I can safely say there is a varst difference in strength between a good lay up and a bad that you can't easily see unless you know what your looking for. Mike |
Reply: 11 - 113 |
Alex_Rowbottom |
Posted on: May 25th, 2014, 22:18:42 |
Reply: 12 - 113 |
Posted on: May 26th, 2014, 07:02:13 |
Don't get me wrong those videos are very good but that guy has clearly been doing it a while. You'll also find the mould that people have may not be suitable for vac bagging (I know mine aren't without work). He also has quite a few pounds worth of equipment at his disposal. The dust from carbon is conductive so kills electric tools it's also not very good for you. I really do recommend doing a coarse atleast you will then know what your getting yourself into. Mike |
Reply: 13 - 113 |
Rodger Howard |
Posted on: May 26th, 2014, 08:07:50 |
I understand the principle " because i can" as much as any other person given the lengths i have gone with my car... However, what is the point of a 400 hp carbon panelled marcos? Do you honestly expect it to handle?
Reply: 14 - 113 |
