what carb?? (currently 2,056 views) |
Ollie Clarke |
Posted on: October 14th, 2010, 20:27:07 |
i have a 1380 engine it has a few bits missing and one of these is the carb a(manifold also) what do you all think i should be looking out for?? twin? twin choke? 1.5"? any advice gratefully received! |
Logged |
Peter Bremner |
Posted on: October 14th, 2010, 22:33:27 |
How about the reliable SU 1 3/4? On a MiniSpares manifold. Available, easy to set up, good on emissions and powerful. A Weber 45 on a Maniflow 6" manifold is a popular choice. My engine builder advised against the Weber because it's not really designed for siamese ports. Often, at low revs, a couple of cylinders will drop out making it very lumpy for around town use, fine for flat out racing. |
Reply: 1 - 11 |
Ollie Clarke |
Posted on: October 14th, 2010, 22:59:37 |
i assume the weber manifold fits fine in the limited space?? Also does anyone at the club know how to find out any history on an engine? say if i had a engine number will there be any records of it? (need to find the number first!!) |
Logged |
Reply: 2 - 11 |
Ollie Clarke |
Posted on: October 14th, 2010, 23:00:02 |
Logged |
Reply: 3 - 11 |
Ian Crowe |
Posted on: October 15th, 2010, 07:14:35 |
Reply: 4 - 11 |
Posted on: October 15th, 2010, 08:13:48 |
To fit a weber you will need to make an air box in the bulkhead. (There is a short thread on the forum somewhere about it. )
SU fits without the need for body mods. |
Reply: 5 - 11 |
Posted on: October 15th, 2010, 23:29:10 |
Unless you've go a modified bonnet (or Mk.V type) use twin HS2s for economy (with a standard Maniflow/RC40 system) or for performance use twin HS4s and a 2" exhaust system. With an extra bulge you can use a single HIF44 which is a pretty good choice. |
Reply: 6 - 11 |
Ollie Clarke |
Posted on: October 16th, 2010, 09:42:54 |
i need a new bonnet so modifying one might not be a problem! Having found out that its a 1380 engine i think i would go for performance, lets see what ebay has to offer...!! |
Logged |
Reply: 7 - 11 |
Peter Bremner |
Posted on: October 16th, 2010, 20:03:04 |
Here's my bulge!
and my airbox for Weber 45 on 6" Maniflow manifold
Engine number is at front of engine, right hand side on a little alloy plate. If the block has been skimmed it may well be missing. |
Last modified October 16th, 2010, 20:07:18 by Peter Bremner |
Reply: 8 - 11 |
Ollie Clarke |
Posted on: October 17th, 2010, 00:36:34 |
I don't normally reply to men showing me their bulge but it is a nice one! i will seek out the engine plate tomorrow. as i need a bonnet i may well try a bulge myself! but i like the idea of the weber (i told my Dad, who used to do some racing and he said if i like a lot of noise go with the weber!) |
Logged |
Reply: 9 - 11 |
Posted on: October 17th, 2010, 09:54:10 |
Quoted from Peter Bremner, posted October 16th, 2010, 20:03:04 at here |
Here's my bulge!
Not only a bulge Peter, you also seem to have a lump as well.
Reply: 10 - 11 |
John Dickens |
Posted on: October 17th, 2010, 20:28:57 |
HIF44 SU on an MG Metro water heated manifold is a good choice for reasonable performance with economy and an easy set up. |
Last modified October 17th, 2010, 20:29:50 by John Dickens |
Reply: 11 - 11 |
