Seat belt mounts (currently 1,252 views) |
Alex Gibson |
Posted on: April 13th, 2008, 11:19:44 |
Sorting out the seat and four point harness mounts today. So i have more questions! Do the lower seat belt mounts (sill & tunnel) have steel reinforcing in them or do i need to put extra spreader plates on the outside? Where is the best place to mount the rear harness straps? (No cage in as yet) The floor seems very flexible and the seat is base mounted, whats the best for reinforcing it? Thanks Alex
Inside every older person is a younger person wondering what the hell happened!!!! |
John Dickens |
Posted on: April 14th, 2008, 11:37:21 |
No & Yes!
There is no steel in the sill or tunnel so you do need to plate them.
You could take the outer lap mount back to the rear subframe mounts rather than the sill?
With no cage your best bet is to go back to the rear floor or to mount a strut between the (reinforced) rear damper mounts and bolt to that. |
Reply: 1 - 1 |
