Rebuilding engine (currently 1,794 views) |
Gert-Jan Westerveld |
Posted on: April 19th, 2008, 17:37:41 |
Today fitted the cylinderhead and started with cleaning the sub-frame.
Rebuild engine 1312CC . |
Reply: 30 - 46 |
Posted on: April 22nd, 2008, 19:25:35 |
At last, the engine is back in the sub-frame. Lovely jobble. ???
how the *$#@!?!!*** are we going to get the engine back in!!.
Rebuild engine 1312CC . | Last modified April 22nd, 2008, 19:30:03 by Gert-Jan Westerveld |
Reply: 31 - 46 |
Bent Larsen |
Posted on: April 23rd, 2008, 13:02:30 |
Reply: 32 - 46 |
Tertius van Zyl |
Posted on: April 23rd, 2008, 14:47:41 Attachment: engine_in.jpg - 61.40 KB (757 views) |
Reputation: -1 (tot: -1) |
The normal way I suppose |
Reply: 33 - 46 |
Posted on: April 23rd, 2008, 20:31:47 |
the big moment is approaching engine is ready to be fitted. It is not going in the way we took it out.
We made us a things to do list, it is working, one day ahead.
Rebuild engine 1312CC . | Last modified April 23rd, 2008, 20:37:54 by Gert-Jan Westerveld |
Reply: 34 - 46 |
Posted on: April 23rd, 2008, 21:24:14 |
One word of warning - lagging the manifold is all very well, but the exhaust pipe will be very much hotter further down, where it gets very close to the fibreglass. You might need to put some heat protection along the edge of the tunnel.
You'll probably want to remove the oil separator on the transfer gear casing in order to attach the engine stabiliser and bolt on the clutch slave cylinder. |
Last modified April 23rd, 2008, 21:30:48 by admin |
Reply: 35 - 46 |
Posted on: April 24th, 2008, 19:19:34 |
thanks fore the warning, the oil separator is mounted fore safety. |
Reply: 36 - 46 |
Posted on: April 25th, 2008, 19:24:07 |
Reply: 37 - 46 |
Posted on: April 27th, 2008, 14:39:49 |
the engine bay is finished.
Reply: 38 - 46 |
Allan Brown |
Posted on: April 27th, 2008, 18:43:21 |
Excellent work. It has been nice to see all the photos of your hard work. |
Reply: 39 - 46 |
Syd Crawford |
Posted on: April 27th, 2008, 22:14:38 |
I like your Hymo scissor lift! That would make it so much easier. |
Reply: 40 - 46 |
Posted on: May 3rd, 2008, 15:47:13 |
I have one problem may engine is leaking oil I hope to repair this before the IMM > |
Reply: 41 - 46 |
Guy Humphries |
Posted on: May 3rd, 2008, 19:31:07 |
Come on Gert-Jan, you can do it.... |
Reply: 42 - 46 |
Posted on: May 4th, 2008, 15:52:19 |
I spend the hole Sunday (in the sun) repairing the oil-separator/distribution-cover. it was leaking oil tomorrow is d-day. Than I will take look if its steel leaking.
Reply: 43 - 46 |
Posted on: May 5th, 2008, 20:13:47 |
problem fixed. To morrow on my birthday I will put it together.
Reply: 44 - 46 |
