Posted on: February 5th, 2018, 19:47:59 Quote Report to Moderator
Quoted from Neil KilBane, posted February 5th, 2018, 09:08:27 at here
Looking good Goff, not too bad a price for the carbs either.
Thanks Neil , Its giving me some heartache this body shell , Today taken the rear subframe off and re-drilled the mounting points as one wheel was sticking out around 12mm further than the other one Grrrrrrrr  and bloody cold working outside , Carbs good buy i have been watching ebay for about 4 months , Prices can vary considerable ,These were pretty local also and not worn on the spindles is a bonus.
Neil are you coming over to Blyton this year ?????
Last modified February 5th, 2018, 19:49:08 by Goff_Allen
Private Message Reply: 105 - 167
Posted on: February 6th, 2018, 09:37:47 Quote Report to Moderator
I won't make Blyton, the dates don't suit this year, I'm heading to Portugal for the IMM in May, can't afford to do both events unfortunately
Private Message Reply: 106 - 167
Posted on: February 10th, 2018, 19:37:06
Gearbox stripped down and washed ,On the wife's worktop for inspection , She wasn't to pleased about it , this was the end of November just found photo ,It needed new layshaft, 4 syncros, all the bearings and a second gear , Bloody expensive to recondition.
Private Message Reply: 107 - 167
Posted on: February 23rd, 2019, 18:19:27
OK ,A bit of a update .
Engine is in , What i did is cranked it over without plugs until i got oil pressure , 75 psi cranking " Great ", connected it all up ,fired up straight away ,Had to cut the front wheel arches as the tyres were catching both fronts on lock , fibre glassed and filled in , looks good now , still doing the body BUT getting close for first coat of polyester spray filler , photos attached , as you can see plenty of dust
Private Message Reply: 108 - 167
Posted on: February 23rd, 2019, 18:22:02
Fitting engine
Private Message Reply: 109 - 167
Posted on: February 23rd, 2019, 18:30:51
its in
Private Message Reply: 110 - 167
Posted on: February 23rd, 2019, 18:32:06
engine
Private Message Reply: 111 - 167
Posted on: February 23rd, 2019, 18:38:05
Plenty of dust
Private Message Reply: 112 - 167
Posted on: February 23rd, 2019, 18:38:33
More dust
Private Message Reply: 113 - 167
Posted on: February 23rd, 2019, 18:39:14
rear light filled in
Private Message Reply: 114 - 167
Posted on: February 23rd, 2019, 18:39:56
Fitted a heater
Private Message Reply: 115 - 167
Posted on: February 23rd, 2019, 18:42:33
Nice rad
Private Message Reply: 116 - 167
Posted on: February 23rd, 2019, 18:44:34
Heater. another update soon
Private Message Reply: 117 - 167
Posted on: March 2nd, 2019, 16:10:31
update - Body is just about ready for first coat , BUT i thought i would offer the windscreen up to see if it would fit , NOPE it needs either the glass grinding and/or the body modifying , I think ill alter the body , on the nearside bottom screen pillar it needs some taking off , same pillar at the top it needs biulding up , photo's will tell the story .
Private Message Reply: 118 - 167
Posted on: March 2nd, 2019, 16:12:52
nearside bottom pillar
Private Message Reply: 119 - 167
Powered by e-blah Platinum 7 Final © 2001-2004   -   October 13th, 2026, 00:47:17
Files opened: 137 | Files closed: 137
