  Mini Marcos Forum  >  General Boards  >  Mini Jem  >  ex Malcolm Fell rally car
  Author    ex Malcolm Fell rally car   (currently 1 views)
Posted on: November 10th, 2024, 20:29:40
I've had this car nearly 10 years but life has generally got in the way. However the boss recently gave the go ahead to retrieve the car and make a start. The car has been stored at a friend's house but as it's been there a while and he's not a keen gardener it has disappeared under rather a lot of brambles. After much hacking we managed to extract the car and load it onto the trailer for the short trip home. This jem will be my wires car so I let her loose with the jet wash while I dropped the trailer back. I returned to find most of the black paint now on the drive, that'll save some sanding. The following day we carried the shell around the back of the house and onto the decking to start the restoration.
Posted on: November 10th, 2024, 20:32:14
After jet wash.
Private Message Reply: 1 - 5
Posted on: November 11th, 2024, 13:26:52 Quote Report to Moderator
Returning to rally spec or something else ?
Private Message Reply: 2 - 5
Posted on: November 20th, 2024, 20:38:37 Quote Report to Moderator
It'll be a road car but along the lines of tarmac rally spec. It will be loosing the MK3 wheel arches but it will get some jem MK2 wider arches. I'm planning to have minimal interior but it will get a full cage.
Private Message Reply: 3 - 5
Posted on: August 24th, 2025, 18:18:00
After a gap to build a camper van in back on this. The floorpan has been repaired and gel flow coated. The shell was then flipped back up the right way to do internal and body repairs, the interior has also been gel flowcoated. Finally body prep and coat of epoxy primer.
Private Message Reply: 4 - 5
Posted on: August 24th, 2025, 18:18:47
Epoxy primer
Private Message Reply: 5 - 5
Powered by e-blah Platinum 7 Final © 2001-2004   -   May 17th, 2026, 18:05:47
Files opened: 119 | Files closed: 119
