Pages: « 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12 » : All |
I have started to build the MK1 Jem (currently 1 views) |
| Goff_Allen |
Posted on: January 10th, 2017, 21:15:49
| both finished ready to paint |
Reply: 30 - 167 |
| Goff_Allen |
Posted on: January 15th, 2017, 21:43:06
| This is the welder i used for welding the bottom arms and also the welding rods , Low hydrogen 7016 or you can used 7018 , painted a few more parts and had them in fron of the log burner to bake awhile , my wife looked but never commented !!!!!! |
Reply: 31 - 167 |
| Goff_Allen |
Posted on: January 15th, 2017, 21:44:07
| Cherry red |
Reply: 32 - 167 |
| Goff_Allen |
Posted on: January 15th, 2017, 21:45:02
| welding rods |
Reply: 33 - 167 |
| Goff_Allen |
Posted on: January 15th, 2017, 21:47:20
| painted parts |
Reply: 34 - 167 |
| Goff_Allen |
Posted on: February 13th, 2017, 20:39:12
| I got a bit more done , Fitted new roller bearings in the top arms using a long bolt and some wide wasers, Assembled and painted the Discs, Calipers warming up ready to paint and Shock absorber brackets de-rusted and painted. |
 | Last modified February 13th, 2017, 20:40:24 by Goff_Allen |
Reply: 35 - 167 |
| Goff_Allen |
Posted on: February 13th, 2017, 20:42:10
| top arm |
Reply: 36 - 167 |
| Goff_Allen |
Posted on: February 13th, 2017, 20:43:45
| top arm |
Reply: 37 - 167 |
| Goff_Allen |
Posted on: February 13th, 2017, 20:49:20
| new discs |
Reply: 38 - 167 |
| Goff_Allen |
Posted on: February 13th, 2017, 20:49:51
| warming up |
Reply: 39 - 167 |
| Goff_Allen |
Posted on: February 13th, 2017, 20:50:27
| undercoat |
Reply: 40 - 167 |
| Goff_Allen |
Posted on: February 15th, 2017, 20:36:10
| I got the calipers and Steering rack painted today , Sprayed them as the calipers are to fiddly to brush , You get more paint on your hands and know way of holding them really. |
Reply: 41 - 167 |
| Goff_Allen |
Posted on: February 15th, 2017, 20:37:48
| steering rack |
Reply: 42 - 167 |
| Goff_Allen |
Posted on: February 18th, 2017, 20:38:58
| Weather was a bit warmer so i got to grinding out the Jelcoat cracks on the roof , Some are cracks , Some are the gelcoat lifting , Looks like someone as attacked the gelcoat with one of those Gouging chisels and it as just started to lift !!!!!!!!! Strange !!!! , I made a couple of inquires and was told to paint first coat with Mastic Polyester Spray Filler !!!!!! I got the body outside today on its side to have a look underneath at the damage or repairs that it needs , Not to bad really , For some reason they have filled the front subframe floor mounts ???? ,I removed a couple of bits of wood that was poorly glassed over, Going to trial fit the front subframe to see if anything is wrong!!! ,Rear arches are a bit rusty but i reckon i can just repair them after removing some matting and grinding away the rusty part, A few photo's added , My wife say's i am crackers , Ha Ha . Maybe she is right ???? |
Reply: 43 - 167 |
| Goff_Allen |
Posted on: February 18th, 2017, 20:41:39
| Roof , Look like it as got woodworm |
Reply: 44 - 167 |
