Pages: « 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12 » : All |
I have started to build the MK1 Jem (currently 1 views) |
| Goff_Allen |
Posted on: October 31st, 2016, 21:31:04
| first coat |
Reply: 15 - 167 |
| Goff_Allen |
Posted on: October 31st, 2016, 21:36:08
| hand brushed wet top coat in all the seams before spraying. |
Reply: 16 - 167 |
| Goff_Allen |
Posted on: October 31st, 2016, 21:38:19
| finished both subframes ready to build up |
Reply: 17 - 167 |
| Goff_Allen |
Posted on: October 31st, 2016, 21:42:33
| Rear arms after a week soaking in molasses and just pressure washed ready to dry and paint |
Reply: 18 - 167 |
| Goff_Allen |
Posted on: October 31st, 2016, 21:44:29
| and painted |
Reply: 19 - 167 |
| Goff_Allen |
Posted on: November 1st, 2016, 11:56:19
| Heating up the Hydro tags on the rear subframe, Tap out flush then i can fit Dry rubber cones |
 | Last modified November 1st, 2016, 11:58:12 by Goff_Allen |
Reply: 20 - 167 |
| Goff_Allen |
Posted on: November 1st, 2016, 11:57:38
| again showing the tag heated up before knocking flush to form a ring so the rubber cone will fit |
Reply: 21 - 167 |
| Goff_Allen |
Posted on: January 10th, 2017, 20:57:15
| I got a bit more done today, Modified a pair of front suspension bottom arms by adding 1/4 inch to make them negative camber , This is how i do mine , The photos should tell the story , Mark and square of with the back part of the arm , This will not change the geometry of the caster angle same as happens when lengthening the arm by cutting and welding in the middle, OK ,Mark out , Cut with a hacksaw , Build up with weld aprox 1/8 inch in the middle , about 3 runs and one run each side , Grind a V prep , Do this to the other piece , Make sure you still have the original hacksaw cut at the edge , so you can measure , or you could just mark the arm either side of the cut and scribe a line to work from , OK so now you have the bottom arm with a V prep ready for welding , Line it all up square and tack weld each end make sure its 1/4 inch gap , If you cannot burn through the root don't worry as after the first run you can grind out from opposite side , Weld on opposite sides to stop it from pulling out of square , Grind and flap disc to finish ,any under cut just use a 1.5 mild steel welding rod to fill in , Stick weld , Use Low Hydrogen rods 7016 or 7018 , pre-heat rods also , I used a bit of scrap plate to start my runs so i don't end up with porosity at the start , About 1 1/2 hrs to do both arms , First time i did this was in 1968 ,Yes 49 years ago . |
Reply: 22 - 167 |
| Goff_Allen |
Posted on: January 10th, 2017, 20:57:57
| arm |
Reply: 23 - 167 |
| Goff_Allen |
Posted on: January 10th, 2017, 21:01:16
| run of plate for starting welding |
Reply: 24 - 167 |
| Goff_Allen |
Posted on: January 10th, 2017, 21:03:38
| V prep |
Reply: 25 - 167 |
| Goff_Allen |
Posted on: January 10th, 2017, 21:05:06
| !/4 inch gap |
Reply: 26 - 167 |
| Goff_Allen |
Posted on: January 10th, 2017, 21:10:05
| Tacked up one side |
 | Last modified January 10th, 2017, 21:10:29 by Goff_Allen |
Reply: 27 - 167 |
| Goff_Allen |
Posted on: January 10th, 2017, 21:13:18
| welded |
Reply: 28 - 167 |
| Goff_Allen |
Posted on: January 10th, 2017, 21:13:59
| finished |
Reply: 29 - 167 |
